Swap
Feb 11, 2019Aspirant
RBS50 always offine
My satellite RBS50 always offline, why is that? No matter you do restart or sync it again n again . It has latest firmware
Feb 11, 2019Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
How are the Satellites connected? Wireless or wired?
What is the Mfr and model# of the ethernet switch if one is in the configuration.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
What WPA security modes are you using?
Try enabling Beamforming and MIMO.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
- CrimpOnFeb 11, 2019Guru - Experienced User
It is probably useful to verify that this is (a) a satellite that is being installed for the first time, or (b) the satellite has been installed and working just fine for a while but suddenly stopped working?
I assume that you have determined the satellite is "offline" by browsing to the Orbi web interface (normally 192.168.1.1, although you may have set it to a different IP). Opening "Attached Devices" and you do not see any "Connected Satellites". Correct?
It appears that you have done a "factory reset", by following these steps:
Unplug the satellite. Put it in the same room as the router, but do not plug it in yet.
Get your trusty unbent paperclip tool.
When you plug in the satellite, press the paperclip in the tiny "Reset" hole until the LED turns orange (yellow?) and flashes.
(holding it in too long is better than too short I didn't wait long enough and thought I was resetting when I actually wasn't.)
Go back to the Orbi web interface and select "Add Orbi Satellite" at the bottom of the Basic tab.
Follow the steps through the Add Satellite pages. The sync process takes longer than I expected it would.
After it finishes, and the lights behave as they are supposed to, go to "Attached Devices" and verify that the satellite appears as "Connected."
If, at this point, the satellite does not show as "Connected", this is not good.
If it does show as connected, then unplug it, put it back where it belongs, plug it in and watch the light show.
Trudge back to the router and refresh the Attached Devices page. If it does not show as connected, now is the time to talk about how far it is from the router and what lies in the path between them.
- SwapFeb 11, 2019AspirantModem: Motorola Arris SB6183
mode: Router
Switch: 2 Netgear (8 and 4 )
Satellite connection: wireless
House size:3500 sq ft
Distance between: around 30-35 ft
2.4 GHz: Auto
5 GHz:48
WiFi near by : 6-7
WPA2- FURRYe38Feb 12, 2019Guru - Experienced User
What is the model# of the ethernet switches in the configuration.
mode: Router
2.4 GHz: Auto
5 GHz:48
WiFi near by : 6-7
WPA2- Chuck_MFeb 12, 2019Mentor
Sounds to me like he hasnt properly setup/paired his satellite, but hard to tell from the description.
