Swap
Feb 11, 2019Aspirant
RBS50 always offine
My satellite RBS50 always offline, why is that? No matter you do restart or sync it again n again . It has latest firmware
Swap
Modem: Motorola Arris SB6183
mode: Router
Switch: 2 Netgear (8 and 4 )
Satellite connection: wireless
House size:3500 sq ft
Distance between: around 30-35 ft
2.4 GHz: Auto
5 GHz:48
WiFi near by : 6-7
WPA2
mode: Router
2.4 GHz: Auto
5 GHz:48
WiFi near by : 6-7
WPA2
Feb 12, 2019Guru - Experienced User
What is the model# of the ethernet switches in the configuration.
mode: Router
2.4 GHz: Auto
5 GHz:48
WiFi near by : 6-7
WPA2
- Chuck_MFeb 12, 2019Mentor
Sounds to me like he hasnt properly setup/paired his satellite, but hard to tell from the description.
