soupbones's avatar
Feb 12, 2021
RBS50 as an extender for Altice Gateway modem.
Optimum has just ran fiber to my house and with it came their Altice Gateway modem. I have been getting "BRS_wanlan_conflict.html" errors on most sites I visit, and the Orbi app says I have no internet connection (even though I do).
So I called Optimum assuming the issue is their modem is conflciting with my RBS50 modem.
Optimum said if I want to continue to use my Orbi mesh network, I need to use them as extenders. They are are unable (or unwilling) to set up the Altice modem in a mode that would make it work with my Orbi.
Can the RBS50 be used as an extender? If so, how do I do that?
