Yatheesh's avatar
Yatheesh
Initiate
Nov 23, 2021
RBS50 Does not connect to Internet
Hi,
I have a RBR50 Orbi modem with RBS50 extension satellite.  Since morning,  RBR50 base station is working fine and provides internet connection to attached devices, however satellite does not. Both the were working perfectly fine till yesterday. Both are using version 2.7.3.22 firmware.  Satellite is connected to basestation(conencts with solid blue light). I tried doing a factory reset for satellite. But still it does not work. My basestation is in ground floor and satellite is in first floor. My house size is  120SQM in GF and same in first floor.
Apprecaite help.
1 Reply
  • FURRYe38's avatar
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
    Be sure the RBS FW is updated to same version as whats loaded on the RBR.
    What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
