SipsTea
Jun 01, 2026Aspirant
RBS50 fails to update but RBR50 is successful
Hi, So I downloaded the firmware from Netgear RBR50-V2.7.6.6 since the router does not find any new version besides the old I have which is 2.7.5.6, updated the main router and it worked perfectl...
- Jun 01, 2026
The satellite firmware file is different from the router firmware:
https://www.downloads.netgear.com/files/GDC/RBK50/RBS50-V2.7.6.6.zip
As FURRYe38 mentioned, I find it easier to connect to the satellite IP address and use the Firmware Update menu selection on the satellite itself.
Jun 01, 2026Guru - Experienced User
What browser did you use? Try MS Edge or Firefox?
Be sure you update the RBS first using its web UI.
Clear out any browser caches.
File should be .chk.
