SipsTea
Jun 01, 2026Aspirant
RBS50 fails to update but RBR50 is successful
Hi, So I downloaded the firmware from Netgear RBR50-V2.7.6.6 since the router does not find any new version besides the old I have which is 2.7.5.6, updated the main router and it worked perfectl...
- Jun 01, 2026
The satellite firmware file is different from the router firmware:
https://www.downloads.netgear.com/files/GDC/RBK50/RBS50-V2.7.6.6.zip
As FURRYe38 mentioned, I find it easier to connect to the satellite IP address and use the Firmware Update menu selection on the satellite itself.
SipsTea
Thank you! I looked for the satellite firmware but couldn't find it on the website only for the main one. I use Firefox and I log in to the web UI orbilogin.net. I use the satellite firmware window of course. I'll try updating and get back you.
