SipsTea
Jun 01, 2026Aspirant
RBS50 fails to update but RBR50 is successful
Hi, So I downloaded the firmware from Netgear RBR50-V2.7.6.6 since the router does not find any new version besides the old I have which is 2.7.5.6, updated the main router and it worked perfectl...
- Jun 01, 2026
The satellite firmware file is different from the router firmware:
https://www.downloads.netgear.com/files/GDC/RBK50/RBS50-V2.7.6.6.zip
As FURRYe38​ mentioned, I find it easier to connect to the satellite IP address and use the Firmware Update menu selection on the satellite itself.
SipsTea
Ok so CrimpOns firmware worked :). Both firmwares ended in .img but they updated fine. So thank you both for your help :).
Before I finish off, since I have two experts here I might as well ask if these settings below (see picture) are best for this router :).
Edit: Ok so I am trying to upload a picture but it says "media upload in progress, please wait a few minutes" and nothing else happens. If I wait the page just reloads after awhile and both this answer and the picture I want is not there, tried uploading from computer and also as a file. So I will have to try uploading it later.
- CrimpOnJun 01, 2026Guru - Experienced User
This is correct. Firmware images for Netgear products typically have files named .chk or .img It may be related to (a) the specific processor chips used, or (b) the programming development language.
Glad it updated.
- FURRYe38Jun 02, 2026Guru - Experienced User
There is a known forum bug that copying and pasting in pictures of a large size isn't working. To get around this, you'll need to use a cloud share service and use the DIRECT LINK option, then as you post, in the editing of the post, use the camera icon then select From Image URL. Poste in the DIRECT LINK. Then your picture should be seen in the post.
Glad you go the RBS updated. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Edit: Ok so I am trying to upload a picture but it says "media upload in progress, please wait a few minutes" and nothing else happens. If I wait the page just reloads after awhile and both this answer and the picture I want is not there, tried uploading from computer and also as a file. So I will have to try uploading it later.- SipsTeaJul 16, 2026Aspirant
Ok FURRYe38​ and CrimpOn​, thank you for your help. I resetted my router after finally getting the router updated and now when I test my connection on the PS3 and PS5 I don't get that good speeds, and also I get information saying something about IP packets which I've never seen before when doing speed tests on the console. Is this something new? Also, for strict gaming content, is it best to disable all the fancy stuff netgear has like MUMO, beam forging etc? Thank you again. I've posted the image below for you to peruse.
- FURRYe38Jul 16, 2026Guru - Experienced User
For any PS console, NAT type will always be Type 2 when behind a router that is behind a ISP modem. Thats standard for Sony.
For best gaming performances, ethernet connected game console to the router is recommended.
If wifi, then you can test features like MIMO or Beamforming enabled or disabled to see if those change the wireless game console performances.
Most wireless game console wifi adapters are not the best for gaming. Why ethernet is recommended.
