SipsTea
Jun 01, 2026Aspirant
RBS50 fails to update but RBR50 is successful
Hi, So I downloaded the firmware from Netgear RBR50-V2.7.6.6 since the router does not find any new version besides the old I have which is 2.7.5.6, updated the main router and it worked perfectl...
- Jun 01, 2026
The satellite firmware file is different from the router firmware:
https://www.downloads.netgear.com/files/GDC/RBK50/RBS50-V2.7.6.6.zip
As FURRYe38 mentioned, I find it easier to connect to the satellite IP address and use the Firmware Update menu selection on the satellite itself.
SipsTea
Ok so CrimpOns firmware worked :). Both firmwares ended in .img but they updated fine. So thank you both for your help :).
Before I finish off, since I have two experts here I might as well ask if these settings below (see picture) are best for this router :).
Edit: Ok so I am trying to upload a picture but it says "media upload in progress, please wait a few minutes" and nothing else happens. If I wait the page just reloads after awhile and both this answer and the picture I want is not there, tried uploading from computer and also as a file. So I will have to try uploading it later.
CrimpOn
Jun 01, 2026Guru - Experienced User
SipsTea wrote:Both firmwares ended in .img but they updated fine
This is correct. Firmware images for Netgear products typically have files named .chk or .img It may be related to (a) the specific processor chips used, or (b) the programming development language.
Glad it updated.
