aibanez2797's avatar
aibanez2797
RBS50 makes network unstable
A while ago, I bought a RBR50/RBS50 combo with one router and two satellites.  From the first day I had it, I couldn't use one of the satellites.  It was running older firmware than the router and the other satellite, and every time I tried to join it to the router, it would make the entire network unstable.  Every device in the house would lose connectivity, nobody could access the network, and of course I couldn't upgrade the firmware on the RBS50 that was causing the problem.  As soon as I would kill power on this satellite, the network would become stable and usable.
Currently, my router and working satellite are running v2.3.5.30, and my laggard satellite is running 1.12.0.18.  Is there any way to make this unit usable with my network?  I would hate to think the money I spent on it was wasted.
    • aibanez2797's avatar
      aibanez2797
      Thanks plemans, but I'm not sure if that is going to help.  That procedure describes upgrading to an intermediate release to get to the current version (a very reasonable approach).  I'm just not sure how to update the satellite if the entire network falls apart as soon as I connect it to the router.  Is there a way to update the satellite without connecting it to a router?
  • FURRYe38's avatar
    Be sure when updating FW on the Orbi system that you update the RBS first, then the RBR.
      aibanez2797
      Thanks FURRYe38, but that describes the precise position I find myself in, from the moment I bought this set.  My satellite shipped with a much older FW release than the router, and I have never been able to get the network stable enough to update it any further.  Has anyone run into this before?  Is there any way to upgrade the FW on the satellite without connecting it to a router?
  • FURRYe38's avatar
    You don't need to use TFTP.
    Just factory reset the RBS after you have downloaded the necessary files. Connect 1 wired PC to the back of the RBS and wait for the PC to get an IP address, should be 192.168.1.something. Open a web browser and input 192.168.1.250. This should open the RBS web page. Admin and PW is password. Once in, send the v2.0.0.74 FW file. After this loads, continue to loading the v30 FW file for the RBS. should be able to go directly to v30 after v74.
    • CrimpOn's avatar
      CrimpOn
      Cool.  I did not realize the satellite would give devices an IP address when it is not connected to the router.  Great tip about the 1.250 web address.
      • FURRYe38's avatar
        Ya I had wondered about that a while back. I happend to do a reset and figured, lets see what happens. Sure enough. PC got an IP address and the gateway IP worked for logging to the RBS. Nice safety feature. :smileywink:
