cargillk
Jan 26, 2021Aspirant
RBS50 no longer showing wired connections
Updated firmware to try and address issue with satellite disconnecting intermittently and now it will not allow the wired NAS drive and Laptop I had hardwired to the satellite to connect to the primary network.
In attached devices I can see the NAS and the reserved IP address but my laptop is not being assigned a wired address from the satellite (wi-fi working fine). Cannot access the NAS from wifi (could before).
Any help welcomed. I will be responsive. I am moderately novice but not rookie.
Yes, power off everything, then power ON the ISP Modem and let it sync, Then power ON the RBR and let it come to ready, Then power ON the RBS.
What Firmware version is currently loaded? What prior version of FW had you loaded?
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed since last update?
- cargillkAspirant
Firmware
- Sattelite and RBR50 are at V2.7.2.102 .
- I have another satellite (RBW30) for the basement that is on V2.6.2.2
- I upgrade from a 2.1 (I don't remember exactly...is there a way to find?)
Router
- ARRIS GROUP, INC. TG3482G (Xfinity)
Power Off and On
- No. I will try that when my work day is done.
- To clarify: Shut down all satellites and ISP modems for one minute then power up. Is there a certain sequence that woudl be helpful?
What mode is your modem in? Router or Modem only?
Your ISP Modem already has a build in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
