0703kb
May 02, 2020Star
RBS50 satellite keeps dropping a wired device (Fingbox) but other RBS50 satellite does not.
I bought RBR50 and RBS50 pack and the later on, purchased an additional RBS50. All working fine. I also have a "fingbox" for managing access to the network. It is wired into a satellite. The problem has been that the fingbox kept dropping off the network - once or twice a day - and would inform me the internet had gone down. Re-plugging the network cable was enough to get the fingbox recognised again. I tried all fixes on the fingbox website, but nothing worked. I then moved the fingbox to the original satellite which came with the pack. This satellite (another RBS50) does not loose connection with the fingbox.
So, do I have a faulty satellite or is there a setting I can make to stop it dropping attached fingbox device? It's the additionaly purchased satellite that looses the connection.
thanks.
Sort By
Try connecting the box to the RBR..
0703kb wrote:The problem has been that the fingbox kept dropping off the network - once or twice a day - and would inform me the internet had gone down.
How does the Fingbox notify you that the internet had gone down? (blink a light? send an email? beep? You have a "Find App" running on a separate machine that does something?)
- I get a notification to my mobile phone that the fingbox has dropped off line. I think that the company has servers which monitor for the device and then notify me when it is not seen. In effect, it is telling me my Wifi network has gone down. But In this case it actually means that the fingbox is no longer connected to Orbi satellite. It ceases to be listed as a connected device even though the fingbox is connected directly by an Ethernet cable into the satellite. It works fine when plugged into the one satellite, but gets dropped a couple of times a day when plugged into the other satellite. I can’t see any specific configuration settings that could be made for satellites in the admin pages. Both satellites are running the same firmware. So the satellites behave differently.
0703kb wrote:
I get a notification to my mobile phone that the fingbox has dropped off line. I think that the company has servers which monitor for the device and then notify me when it is not seen. In effect, it is telling me my Wifi network has gone down. But In this case it actually means that the fingbox is no longer connected to Orbi satellite. It ceases to be listed as a connected device even though the fingbox is connected directly by an Ethernet cable into the satellite. It works fine when plugged into the one satellite, but gets dropped a couple of times a day when plugged into the other satellite. I can’t see any specific configuration settings that could be made for satellites in the admin pages. Both satellites are running the same firmware. So the satellites behave differently.Thanks for the explanation. For sure, there are no "settings" on a per-satellite basis. I am at a loss to explain this situation.
I was unable to find any mention on their website of Fingbox monitoring customer servers. Would it be convenient to take a screen shot of one of these messages that appear in the Fingbox "app"?
There is a definite explanation for a WiFi device "dropping off" the Attached Devices display. My Nest thermostat does that when the app is not open. It only sends/receives data packets when talking to the app, so it goes totally quiet when the app is closed for a while. I was able to reproduce the effect by bringing up Attached Devices (no Nest). Open the app and Nest appears. Close the app and in about five minutes Nest disappears again. This probably does not apply in your situation since the Fingbox app is probably running in the background 24/7 on the mobile phone.
The same ethernet cable is being used with both satellites?
You have tried more than one ethernet jack on the offending satellite?
Are both satellites connected independently to the router, or does one satellite "Daisy Chain" off the other?
