staeren's avatar
staeren
Follower
Mar 18, 2022
RBS50 satellites compatibility?
is there anyone who can tell me with which ORBI mesh wifi systems the RBS50 sat are compatible?
1 Reply
  • plemans's avatar
    You can use the RBS50 satellites with the RBR20, RBR40, RBR50.
    Supposedly you can hardwired it into the AX systems but it doesn't integrate
