lagon_1010
Jul 20, 2025Aspirant
RBS50 stopped working
Over night the RBS50 stopped working. I tried to reset it but it did not work. After a few resets, the reset button does not work anymore. I tried the TFTP client method but my computer doesnt even r...
lagon_1010
Jul 22, 2025Aspirant
Thank you for your suggestions, I tried the 30-30-30 but apart from solid green for power nothing else is lighting up, so into the trash with the whole system :(
Jul 22, 2025Guru - Experienced User
If the RBR is working, you could get another RBS. You can find then still out in the wild.
