jerryschwartz
Sep 26, 2017Apprentice
RBS50 weak signal
I was using Netgear's handy little WiFi Analytics Android tool to map out the signal strength in various parts of my house, and I found that the signal strength in my bedroom is only 86%. What makes ...
martyfp
Sep 27, 2017Luminary
It is possible that the phone is connected to the Router instead of the Satellite. (Perhaps they are a little too close together?)... I also think that when you get very close to either the satellite or router then the signal strength does drop due to near field effects, this is normal.
If you're using the latest firmware (2.0.0.74) then you can tell which devices are connected to the router or satellite in the "Attached Devices page"
If you turn off wifi on the phone then re-enable then it should connect to the stronger signal.
There is a new option in the Advanced wireless settings that enable "Fast Roaming", that should encourage your phone to switch between router and satellite more aggressively.
