ileodo's avatar
ileodo
Tutor
Jan 05, 2020
RBS50 wired backhaul shown as 5G/2.4G in AP Mode
Here is my setup:
Internet ---WAN---> X4S R7800 (Router/Gateway)-- LAN#1 ->  RBR50 LAN#1 (AP mode)
                                                -------------------------LAN#2 ->  RBS50 LAN#1
both of RBR50 and RBS50 has framework v2.5.1.8 (latest as of now).
Here is my problem. As I mentioned, in the setup, it's a wired backhaul, however, in the admin dashboard of the RBR50, the protocol of the backhaul is shown as 5G/2.4G but not Ethernet. the status of the backhaul is shown as poor.
Any idea about why? Please let me know if you need more information.
Thanks.
  • CrimpOn's avatar
    CrimpOn
    Have you tried connecting the RBS50 to one of the LAN ports on the RBR50, rather than to the R7800?
    • ileodo's avatar
      ileodo
      Tutor
      it would be very difficult to test that in my case. (realy hard to move the RBS). but why that matters?
      • CrimpOn's avatar
        CrimpOn
        Well, sorry.  My Orbi WiFi is located right next to my modem, so I just assumed that your Orbi was right next to the R7800 and that it would be a simple matter of moving the cable.  So, those "LANs" are switches located in different areas away from the R7800?
  • ileodo wrote:
    Here is my setup:
    Thanks.
    Try this wiring:
    • X4S LAN#1 -> RBR50 yellow (WAN) port (not RBR50 LAN#1)
    • RBR50 LAN#1 ->  RBS50 LAN#1 (wired backhaul)
    • CrimpOn's avatar
      CrimpOn
      Good catch.  I missed that completely.
    • ileodo's avatar
      ileodo
      Tutor
      There is only one cable from RBR to the router and one from RBS to the router.
      • CrimpOn's avatar
        CrimpOn
        I think the point was to confirm that the RBR was connected to the router from the yellow (WAN) port, not LAN port 1.
