Gharam
Jun 26, 2020Aspirant
RBS50v2 and RBS50 Satellites together in one Network with RBR50 Router...
Hello guys...
I used Orbi product sence years. (RBR50 Router & RBS50 Satellite). and And there isn't any problem. but before a month, I bought another Satellite (RBS50v2). When I added it into my Orbi Network.. When I open the orbi app, I Noticed this thing (You can see it in the figure)
And when I enter the Network Map, I Notices a pink circle near the RBR50 Router,..
(((THERE IS NOOO PROBLEM WHEN I RESET THE NETWORK WTHIOUT RBS50v2 SATELLITE)))
SO,
>>>> Is there any problem when you add different versions Satellite in the same Network???? :( <<<<
Gharam wrote:>>>> Is there any problem when you add different versions Satellite in the same Network???? :( <<<<
There should be "no problem." Notice the "What Do I Need?" on page two of the Product Data Sheet
https://www.netgear.com/images/datasheet/orbi/RBS50v2.pdf
Are you able to access the Orbi web interface? (not the "App")
- GharamAspirant
I'm really don't know what do you mean about orbi web interface!..
Gharam wrote:I'm really don't know what do you mean about orbi web interface!..
In addition to the Orbi "app", the router includes its own web server that provides access to many settings and reports that the app does not. Navigate any web browser to http://orbilogin.net. When the Orbi comes "out of the box", the administrative credentials are set to "admin" and "password". This is the way routers have been set up for 20 years. (before "apps" existed). It is easiest to access the web interface using a computer (a) because the web pages are a bit too large for a tiny smartphone screen, and (b) a keyboard and mouse make manipulating the web pages much easier. A tablet (iPad, Android) will work, but is more cumbersome.
This is described starting on page 20 of the User Manual:
https://www.downloads.netgear.com/files/GDC/RBK50/Orbi_UM_EN.pdf
