dkornaros's avatar
Feb 24, 2023
RBS50v2 corrupted firmware (red blinking power light). How do I restore firmware?
Mac only home (somewhat of a power user, but definitely NOT terminal/shell script literate). RBR50v2 is working fine connected to an older RBS50 satellite.
However, RBS50v2 somehow got stuck in an upgrade and is now corrupted (red flashing power light). How can I restore my RBS50v2 to factory settings when firmware is corrupted?
What have I done?
- Reboot unsuccessful
- Factory reset unsuccessful
- Found forum with nmrpflash solution, can't figure out how to make it work. I downloaded nmrpflash and installed Homebrew but can't figure out how to execute commands. Every response is either "nmrpflash command not found" (from root) or "brew command not found" (from home folder).
    • dkornaros's avatar
      dkornaros
      Tutor
      Thank you for your reply.  I tried that, but likely due to my inexperience executing terminal commands, I could NOT get it to work. I enabled root user, logged in as root user, downloaded nmrpflash from the same link you provided, and tried to execute nmrpflash -L
      Reply: "nmrpflash command not found"
      I have no idea what I'm doing wrong
      • FURRYe38's avatar
        Be sure you are using the command line with in the folder path where that program is located.
        Be sure you have the Pre-Requisites installed as well.
