edski2023
Mar 04, 2023Aspirant
RBS50v2 satellite with bad firmware
I bought a used RBS50v2 satellite online and when trying to add it to existing network it blinks red and flashes white which indicates bad firmware. How do I download and fix firmware if it will not connect to the network?
Some people have reported success using TFTP or nmrpflash:
https://kb.netgear.com/000059633/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP-client
https://github.com/jclehner/nmrpflash
The process is sort of technical and can be a challenge.
Take you time and follow the guides closely as well as spelling/punctuation as it can make a difference.
I'd also advise trying several times. TFTP can be sensitive to timings and sometimes takes a few tries.
Excellent advice. And you can add to it by trying some fp the videos that take people through the process.
For example:
Different device, same approach.
