mkasznel
Dec 04, 2020Aspirant
RBS50v2 won't sync with RBR50 router: "Config Sync" issue
About two weeks ago, my Orbi RBS50 satellite stopped working overnight for no apparent reason. Tried power cycling both the satellite and my RBR50 router (as well as my Nighthawk CM1200 modem), resto...
Dec 04, 2020Guru - Experienced User
Try a factory reset on the RBR and RBS this time as setup from scratch. Bring the RBS near the RBR or in same room. Press the sync button on the RBS the RBR.
mkasznel
Dec 14, 2020Aspirant
Hello - sorry for taking so long to reply, got caught up with work!
I appreciate your help. I factory reset both the router and satellite (and also my Nighthawk modem just for good measure), put them in the same room, and set up the network from scratch. Unfortunately, I'm still having the same issue; satellite shows up in the desktop dashboard, but backhaul status is still "Config Sync," satellite does not appear in the Orbi app under Network map, and devices won't connect to the satellite via Wifi. Devices I hardwire to the satellite don't get network connection.
I'm beginning to wonder if it's something wrong with the router? The router still works as a standalone device, but between my original satellite and my new one obtained via RMA (after swapping out the old one), this is two satellites with the same exact issue. :-\
- FURRYe38Dec 16, 2020Guru - Experienced User
You might try downgradng to v16 on the RBR and RBS and see...
mkasznel wrote:Hello - sorry for taking so long to reply, got caught up with work!
