texashoki's avatar
texashoki
RBS50Y -2CCNAS vs 200NAS
Recently purchased a RBS50Y and noticed that the full product code is "RBS50Y-2CCNAS" whereas everything I see online has the "-200NAS" suffix. Does anyone know the difference and if it is the same product or if there is something different? Thanks in advance.
  • CrimpOn's avatar
    CrimpOn
    Can you post pictures of where RBS50Y-2CCnas appears on the packaging? (or the product label?)
    Could there be a chance that it was supposed to be 200 and the zeros did not print completely?
    • texashoki's avatar
      texashoki
      It is on the bottom of the box-Sorry, not sure how to post picture, does this work?
      I am wondering as it has a number to Costco Netgear tech support if maybe this was the Costoco version?
      • CrimpOn's avatar
        CrimpOn
        The bar code is correct: https://www.barcodelookup.com/606449140545
        Says RBS50Y-2CCNAS plain as day.
        This appears to be the original model that was not compatible with the WiFi6/6E products.
        I'm sure you searched Netgear's web site and the general internet as I did..... and got nothing!
