HenkD
Aug 10, 2024Aspirant
RBS50Y doesn’t connect to RBR20
I recently bought a second-hand outdoor Orbi RBS50Y. I want to connect it to my Orbi RBR20, which already has 3 indoor satellites connected to it. But the connection fails every time. What I have already tried: 1) reset the unit; 2) set the unit back to 'Orbi mode'. Could it possibly have something to do with the fact that I have my Orbi router in 'AP mode'? Do I perhaps need to set it back to 'router mode' first? I hope someone knows a solution
What happens if you set the RBR20 to router mode temporarily and then try to connect to the RBS50Y to the RBR20...
I presume that you have done a factory reset on the RBS50Y and setup from scratch...I'd turn OFF all other connected RBS while you work with the Y RBS. Have the Y RBS in same room as the RBR.
What is the brand and model# of the host router the RBR20 is connected to in AP mode?
How is the RBR20 configured for AP mode? Static IP or Dynamic IP?
