darrenplumb's avatar
darrenplumb
RBS50Y Firmware Canada
Hi There, I live just outside Toronto and have a RBS50Y (bought in the US) Outdoor running on my system. Suddenly it stopped working and would not update. I have done a factory reset of my system and got it running again. I wanted to know what firmware I should be running on that... Currently I am running V2.3.5.32
When I access the updates through my web browser it tells me "update failed". Does anyone have any experience with this?
I can of course manually update. I was not sure which firmware to download and install.
Many thanks in advance.
    • darrenplumb's avatar
      darrenplumb
      Thanks for your feedback. I did see that site earlier. Just wasn't sure which one I should use. Setting this stuff up is not my area of brilliance.
      • FURRYe38's avatar
        If you have the RBSY connected to a Orbi home model system, then I believe what you have is correct. If you have a Orbi Pro, the use the Orbi Pro version for the RBSY. If your using a non NG wifi router, then you'll need to use the Extender mode FW on the RBSY.
