dufunnel's avatar
dufunnel
RBS50Y in Extender Mode
I am running into this same issue.  The replies seem to stop in this thread, and the "kb" links no longer work.  Can someone help or point me to how I can get my RBS50Y into extender mode?
  • CrimpOn's avatar
    CrimpOn
    dufunnel wrote:
    RBS50Y-100NAS. It was new in a sealed box.
    Netgear provides 90 days of 'complimentary support' with the purchase of a new product.
  • I'm not seeing a way to update the firmware until it's connected to the router either, which is obviously a problem since I can't get it into extender mode.  Am I wrong or is there a way to manually update firmware without going through a router?
    • FURRYe38's avatar
      If the RBS50Y is in Orbi mode, and to get into Extender mode, You'll need to get it connected to a Orbi 20, 40 or 50 series RBR router first, long enough for the Y to connect and then you would send over the Extender FW, once sent and updated to that FW, then you could set up the Y unit on a non Orbi router system.
      • dufunnel's avatar
        dufunnel
        That's not possible. I have an RBR660 and Netgear claims it is compatible in extender mode. If I can't get it into extender mode without additional hardware, it is useless to me.
  • CrimpOn's avatar
    CrimpOn
    What is the model number on the product label
    • RBS50Y
    • RBS50Y2
    The product description for the original RBS50Y does not mention extender mode, which is prominently mentioned on the product description for the RBS50Y2.
    • dufunnel's avatar
      dufunnel
      RBS50Y-100NAS. It was new in a sealed box.  Indeed the installation instructions do not mention extender mode.  Am I able to update firmware or something to enable it, or is there no extender mode on this model?
    • dufunnel's avatar
      dufunnel
      Unfortunately I've seen that and tried the "Set Up Your Satellite in Extender Mode" just like the original post, with no luck.  Get to step 6 and the satellite only blinks white, never white & blue.  My problem is clearly I can't get it into extender mode, but none of the documentation I have seen online actually works to get it into extender mode.
