jmschnur923's avatar
jmschnur923
Luminary
May 09, 2018
Rbs50y install
The firmware for the rbs50y is behind the rbk53 firmware. How do I install the rbs59y into a two sat system. The therbs50 should be arriving this weekend.
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello Jmschnur923
    The unit should still connect to the router and once it is connected upgrade the firmware on all units to the latest firmware.
    DarrenM
    • jmschnur923's avatar
      jmschnur923
      Luminary
      So the fact that the rbs50y has a lower version than the router and the other sats will not harm performance of the system as a whole?
      • DarrenM's avatar
        DarrenM
        correct
        DarrenM
