ChargerMan426
Feb 20, 2019Tutor
RBS50Y not syncing
Just purchased a RBS50Y to add to my RBK50 sytem. When I try to sync I always end up with a solid magenta light. I've tried moving the satellite closer, futher away, resetting it, powering it on an...
ChargerMan426
Feb 20, 2019Tutor
FW on the router is V2.2.1.210.
Sysco DPC3010 is what the current modem is.
Going through your link now but given the RBSY has no ethernet port how would I be able to hook into it to force an update?
Feb 20, 2019Guru - Experienced User
Ok, I forgot about the RBSY not having a port. Hmmm...
I think this maybe something you need to contact NG support about.
If you reset the RBSY and trying to sync it while in the same room and it's failing to show a BLUE led status and only PINK, seems that the RBSY isn't getting connected correctly. I know there are two modes the RBSY work in, Orbi and and Orbi Extender Mode. There are two varients of FW for this unit.
