ChargerMan426
Feb 20, 2019Tutor
RBS50Y not syncing
Just purchased a RBS50Y to add to my RBK50 sytem. When I try to sync I always end up with a solid magenta light. I've tried moving the satellite closer, futher away, resetting it, powering it on an...
ekhalil
Feb 20, 2019Master
ChargerMan426 wrote:
Just purchased a RBS50Y to add to my RBK50 sytem. When I try to sync I always end up with a solid magenta light. I've tried moving the satellite closer, futher away, resetting it, powering it on and off, etc. I've tried using the hard sync button on my router as well as trying through iOS and the web portal. Please help!
If you have Daisy Chain enabled then the RBS50Y will try to connect to either the router or the satellite in your existing RBK50.
Please disable Daisy Chain and try the Sync again.
ChargerMan426
Feb 20, 2019Tutor
When I chated with techsupport they said the unit is bad and I needed to return it. I currnetly only have the RBR plugged in so the new RBSY only has the RBR to comunicate with.
- FURRYe38Feb 20, 2019Guru - Experienced User
Would be best to return it and if you can get one from Amazon, then that unit should be covered under NG support and warranty.
- Chuck_MFeb 20, 2019Mentor
You did note the comment about daisy chain right?
Even tho tech support says it is dead, it may not be.
I would double check that before calling it quits.
- ChargerMan426Feb 20, 2019Tutor
I did, but while setting things up I only had my router turned on so no other satellites that would be messing with this add on unit.
