TC_in_Montana
Feb 02, 2019Virtuoso
RBS50Y (Outdoor Satellite) in non-Orbi Extender Mode
Supposedly you can set up the Outdoor Orbi Satellite (RBS50Y) into non-Orbi Extender mode to allow it to be an extender off of a non-Orbi router.
According to the limited documentation about...
schumaku
Feb 02, 2019Guru - Experienced User
Wild guess you talk of these two links:
How do I set up my Orbi Outdoor Satellite in Extender Mode?
RBS50Y Firmware Version 1.0.0.30 (Orbi Extender Mode)
Lots of confusion...
TC_in_Montana
schumaku Those are the pieces of documentation (or lack thereof) that I am speaking of.
FURRYe38 So, from one of the posts in the thread you noted, it appears I MUST flash the other EXT firmware before I can put it into EXT (non-Orbi) mode.
Thanks to the both of you for responding. Hopefully a few more users will give some additional guidance. If not, I guess I'll dive into the deep end, and hope no rocks underneath the surface.
- FURRYe38Feb 02, 2019Guru - Experienced User
Let us know how it turns out. Hope it works for you.
- TC_in_MontanaFeb 02, 2019Virtuoso
Well, I know that it is definitely NOT flash the EXT version of the firmware first. I tried that and it said it was not a valid or correct file.
So, maybe it is something they tried... but never really got it working.
I'll keep trying things - if I make any progress, I will update this thread.
- FURRYe38Feb 03, 2019Guru - Experienced User
If you can't seem to get it working, you might contact NG support and have them help you out. Sounds like someting is missing from the setup steps.
