PCroger's avatar
PCroger
RBS50Y Outdoor satellite
Hi all,
I’m based in the UK, I can’t seem to find anywhere stocking the RBS50Y outdoor satellite anymore (in the UK). Is there a new alternative outdoor satellite that works with the Orbi RBS50 (full system known as RBK53S in the UK). I did have a look at the NETGEAR AX1800 outdoor satellite, but I can’t see anywhere if it is compatible.
Anyone had any luck with adding a newer type satellite or aware of any alternatives?
Thank you,
Best,
Pete
    • PCroger's avatar
      PCroger
      Thank you very much for this. I hadn’t appreciated that the RBS50Y only works in extender mode rather than Orbi / Mesh Mode. I have therefore looked further into the NETGEAR AX1800 outdoor satellite. The documents state that it is ‘Business class WiFi based on next generation 802.11ax WiFi 6 technology on both 5.0GHz and 2.4GHz bands. (Backward compatible to 802.11b/g/ n/a/ac).’ My question is, being backwards compatible, would this connect via Wi-Fi and extend or would it require a LAN/Ethernet physical connection? Thank you.
      • CrimpOn's avatar
        CrimpOn
        AX1800 is a marketing term relating to some theoretical WiFi speed, not an actual Netgear product number.
        Which specific device are you considering?
