Alex-
Nov 21, 2025Aspirant
RBW30 satellite: Manual update fails
The instructions to manually update the firmware of an Orbi satellite fail at step 5: "If the browser asks you for the admin password, enter the same password you entered for the Orbi router." ...
Alex-
By the way, sign-in prompts on any other item in the orbilogin.com interface accept the user and password input without issue.
Combine this with the fact that online update doesn't work either, this looks like an intentional limitation by Netgear to annoy customers using older products.
Nov 21, 2025Guru - Experienced User
Highly doubt that.
Thought all Orbi AC series is EoL. There still usable.
Try using admin and password and the log in. Sometimes if the RBW hasn't been fully sync, may use default log in.
