Alex-
Nov 21, 2025Aspirant
RBW30 satellite: Manual update fails
The instructions to manually update the firmware of an Orbi satellite fail at step 5: "If the browser asks you for the admin password, enter the same password you entered for the Orbi router." ...
Alex-
Yes, the RBW30 does have its own webpage, but the sign-in prompt denies the default "admin" and "password". After I reset the device, I noticed that it continued to identify itself with the custom name I had given it. Do you think this might indicate that the reset did not complete?
Nov 21, 2025Guru - Experienced User
What is the RBW connecting too? and RBR or something different?
