Alex-
Nov 21, 2025Aspirant
RBW30 satellite: Manual update fails
The instructions to manually update the firmware of an Orbi satellite fail at step 5: "If the browser asks you for the admin password, enter the same password you entered for the Orbi router." ...
Alex-
Thanks CrimpOn, for assisting! I found the cause of the problem. I contacted the previous owner, who gave me the password he used, which is accepted in the sign-in prompt. This means that the real problem is the reset, which did not actually reset the device. I am going to try a reset for the third time...
Nov 21, 2025Guru - Experienced User
Try a 30-30-30 reset instead of the normal reset, this should really clear out any prior creds.
