stevefxp's avatar
stevefxp
Apprentice
Mar 19, 2020
RBW30 Shows Disconnected
When I look atg the admin console I show my RBW30 as disconnected, even though I know it is working. Why is this happening and is there a way to resolve this? I have rebooted the RBW30 several times but no go.
RBW30 - firmware 2.3.5.6
  • CrimpOn's avatar
    CrimpOn
    Does "know it is working" mean that the Attached Devices page shows devices connected to this satellite?
    • stevefxp's avatar
      stevefxp
      Apprentice
      In reality I do not really know if it is broadcasting...I see it lit up with blue light, assumed it was connected.
      I cannot delete this either, which is disconcerting. I may remove it all together and then try to sync it again.
      • CrimpOn's avatar
        CrimpOn
        Oh, yes. Blue light for 3 minutes, and then no light at all means "good".
        https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean
        I do not understand "cannot delete".  On the Attached Devices page where it shows the satellite Disconnected, just click on "Remove" and then confirm.  Or, is there a difference between "delete" and "remove"?
