jfoxny
Aug 23, 2017Tutor
RBW30 won't connect
Bought a RBW30 - AC2200 satellite add-on but it will not connect to my existing Orbi system (RBK50 - AC3000). The ring flashes white, then turns blue, then turns magenta no matter where I place it an...
DarrenM
Aug 25, 2017Sr. NETGEAR Moderator
Hello Jfoxny
Did you try to factory reset the rbs30 unit? Hold the reset button for 10 seconds then try the sync again.
DarrenM
DarrenM
Aug 30, 2017Sr. NETGEAR Moderator
You should contact support they will be able to replace the unit or help troubleshoot the issue.
http://www.netgear.com/support/contact.aspx
DarrenM
