danielj
Jul 15, 2017Aspirant
advice re home network setup
Hi! i'm looking for some advice re the best way to setup my home network. I just replaced my 2 wireless access points with the orbis setup. I am currently trying to work out the best way to pu...
netwrks
Jul 15, 2017Master
You can configure the Orbi as an AP. Give it a static (unused) IP(s) in the range of the CG3100D, or let DHCP serve it an IP addresses. Shouldn't matter where you put it. Off the CG3100D, or, one of your switches. Whatever makes the best sense, coverage wise..
