AmitR
Jan 17, 2018NETGEAR Employee Retired
Announcing availability of OrbiOS 2.1
I posted this on a different thread, but copy & pasting it here for more visibility. Let me give you a quick update on where NETGEAR is with the OrbiOS. Just before Christmas break, we paus...
mgdurand1
Jan 21, 2018Luminary
Ditto. Rock solid for 2 days straight.
sleepr88
Jan 22, 2018Apprentice
Netgear, since you can't seem to fix the Orbi, are you going to start issuing refunds? or exchanging everyone to Orbi Pros (which doesn't appear to have these problems, because you value business customers over regular consumers?)?
- Alex_07Jan 22, 2018Guide
Very stable for me, all wifi options checked. The only issue i have with the last firmware is i can't see connected devices
- TaptkegJan 22, 2018Tutor
I am running firmware 2.1.2.18 and am still having wifi disconnects during the day. It's frustrating. Streaming services stop and my devices ask for passwords each time they're disconnected. Is this something still being worked on for another firmware update? Is there a place I can share my logs to see if there's another issue that can be corrected?
- TrailermanJan 22, 2018Guide
I'm getting constant loss of internet on Orbi connections ATM. Seems totally random - fine for a couple of hours, then bang, no internet on any of our units (I have router + 3 satellites) for upwards of an hour, then back to normal and so on ad nauseam.
This is becoming a real problem. Do I send this back, is this a known issue, does it need a new firmware update - any concensus on what the problem/solution is?
