AmitR
Jan 17, 2018NETGEAR Employee Retired
Announcing availability of OrbiOS 2.1
I posted this on a different thread, but copy & pasting it here for more visibility. Let me give you a quick update on where NETGEAR is with the OrbiOS. Just before Christmas break, we paus...
Tgterm
Jan 26, 2018Guide
Similar experience here with Daisy Chain on 2.1.2.18. When I have it enabled, frequent 'no internet connection' issues with satellites when using an iPad. Since I disabled it, so far so good...
fitsnugly
Jan 26, 2018Star
Well I've been bumped to L3 support and given a special debug version of the current firmware to install and grab more logs. Hopefully this will help track down the random reboots some of us have...
- sleepr88Jan 26, 2018Apprentice
How long for a Chromecast/Android fix Netgear?.. Netgear still needs to come up with a fix for their end... TP-Link, Linksys, and others have done it already... and I have all my CAST devices unplugged, and uninstalled Google Home app from my phone and I am still having issues with the Orbi, so Netgear has another issue to address also... does Netgear even care?
- psrtx1Jan 26, 2018Star
Fully agree that Netgear needs to address some stability and connectivity issues outside of the Chromecasr/Android bug.
- Wired backhaul is not stable and just connecting statalite to wired connection causes the Router to reboot (should be easy enough for netgear to reproduce)
- Devices randomaly disconnect and reconnect to wifi (all while stationany and with good wifi signal)
- Ping times to the router can go flactuate anywhere from 5-9ms to 20-50ms to 500+ms
P.S. Lot more stable then previous 2.1x release and beta, but not quite upto stability of even a $100 router.
- webminsterJan 26, 2018Luminary
wrote:Fully agree that Netgear needs to address some stability and connectivity issues outside of the Chromecasr/Android bug.
+1 this.
