bolingde
Oct 30, 2018Guide
Another smart plug question
I have a smart plug and like most it only works at 2 4G. Yes it seems like it should work with the 2.4 channel on the orbi but it doesn't, because the Smart Life app states "it will only work on 2.4g ...
Oct 30, 2018Guru - Experienced User
What FW is currently loaded?
Try setting WPA2 and AES only or try WPA and Auto.
Try disabling WMM as well and see.
Advanced Wireless Settings both 2.4GHz and 5GHz changed CTS/RTS Threshold to 2307.
https://community.netgear.com/t5/Orbi/Orbi-RBR40-RBS40-V2-1-4-16-mesh-network-drops-connection-to/m-p/1601598/highlight/true#M35230
Change the CTR/RTS threshold values for both 2.4 GHz and 5 GHz (2341 and 2345 respectively), changed preamble modes to long preamble, and Set 20/40Mhz Coexistence to 40Mhz only.
v210 Daisy chain fixed:
https://community.netgear.com/t5/Orbi/Orbi-doesn-t-work-with-Chromecast-Please-help/m-p/1652882/highlight/true#M43708
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.
https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-and-connection-problems-Skybell/m-p/1649275/highlight/true#M43001
bolingde
Oct 31, 2018Guide
Thanks but that sounds like lot of configuration for something that may/may not work for 5 minutes and may break something else work. BTW, FW is up to date and I changed the channel to 1 and neither worked. It really seems like an underlying problem with mesh networks (at least orbi). Everyone is using smart home devices and if netgear can't come out with a simplified solution I think it will be the death nail for the orbi.
- FURRYe38Oct 31, 2018Guru - Experienced User
I would try the suggestions. Others have been able to get some working.
Not all smart devices are compatible with MESH systems as well. You should contact the Mfr of the device to ask about this.
Good Luck.
