Duncan9988
Jul 10, 2018Aspirant
Backhaul status “config sync”
I bought 2 additional satellites, setup was easy, all was fine and then my original satellite from the kit now shows as Amber in the iOS App and has a Backhaul Status of Config Sync. I have tried mult...
Duncan9988
Jul 11, 2018Aspirant
The router and all satelites are currently on the most recent FW version (v2.1.4.16) this Backhaul status change only happened a few days ago, prior to that it was working fine, that is what has confused me so much :s
Ulairi
Jul 11, 2018Luminary
Have you tried a factory reset? Hold the reset button down for at least three seconds until the power led turns amber. You'll need to set the entire system up again from scratch, but this often clears out issues.
