luaarnhold
Aug 14, 2025Follower
Can Orbi RBR50 connect via WiFi when used as an access point?
Can Orbi RBR50 connect via WiFi when used as an access point or does it have to be via ethernet cable? I have a google wifi mesh system setup and am trying not to have to buy more google wifi, so I ...
Aug 14, 2025Guru - Experienced User
Unless you got the orbi for free, its best to stick with a single mesh system.
They aren't compatible and will just end up ruining the whole point of having a mesh system (seamless roaming)
