jyun
Dec 12, 2017Tutor
Can we downgrade the Orbi 2.1.1.12 firmware?
I have searched and cant find anyone who can confirm that they have downgraded from v2.1.1.12 back to v2.0.0.74. I am reading in these forums and other areas of the internet mixed reviews and results...
BallHawk45
Feb 09, 2018Tutor
Oh sure, you CAN downgrade the firmware to a prior version - but the Orbi will auto-update itself to the latest version within a few hours or days and there is NOTHING you can do to stop it. There is no option to disable this, although many including myself have tried - just search this forum for "NVRAM settings" if you're up for telnetting into your router and satellites to make these changes - but they don't work. Eventually you will wake up to the new firmware and you will be doing the daily/weekly "Orbi Firmware Backrev Dance" along with me and many others.
If you're inclined, you can upvote this suggestion in the Netgear "Idea Exchange" to allow users to opt out of firmware updates:
PyroDog
Feb 09, 2018Apprentice
wrote:Oh sure, you CAN downgrade the firmware to a prior version - but the Orbi will auto-update itself to the latest version within a few hours or days and there is NOTHING you can do to stop it. There is no option to disable this, although many including myself have tried - just search this forum for "NVRAM settings" if you're up for telnetting into your router and satellites to make these changes - but they don't work. Eventually you will wake up to the new firmware and you will be doing the daily/weekly "Orbi Firmware Backrev Dance" along with me and many others.
I second this. I'm lucky enohg tu be running the Orbi system in AP mode behind a router with firewall capability. I use the firewall to block updates. This has been the only solution for me to the forced updates.
- globespyJul 18, 2018Apprentice
what about this?
https://community.netgear.com/t5/Orbi/Firmware-V1-12-0-18-Discussion/m-p/1323973#M10304
