freakievinnie
Oct 04, 2018Star
Firmware 2.2.1.210 and connection problems Skybell
Yesterday I manually updated the firmware (2.1.4.16) of my Orbi RBR50 and RBS50 to 2.2.1.210. All devices quickly connected except for my Skybell Trim Plus doorbell. So I reset the router and satelit...
- Oct 10, 2018
Thank you all for your imput/help. It took a lot of time and frustration but my Skybell is online now for almost 2 days.
Luisfo
Oct 11, 2018Aspirant
Please Help!
I dont know what im doing wrong,
Attached its my info, can you help me with the correct configuration Numbers in my case?? Thanks!
tarxvf
Oct 11, 2018Guide
Its the IP address in your case, use the ones i have listed below
It will ask for the following:
-Password: This will be your WiFi password
-Keep it at WPA2
-IP Address: (see gateway first) Use the first three numbers from your default gateway and 201 for your 4th number (e.g. if your gateway is 10) Use - 10.0.0.201
-Subnet Mask: 255.0.0.0
-Gateway: Use the number that follows "Default Gateway/Router" for your router/extender that you are using to connect the device: Use - 10.0.0.1
-DNS: 8.8.8.8
- cool2562Oct 11, 2018StarSubnet mask would be different if the default gateway is 10.0.0.1
Subnet - 255.0.0.0
Anyone having issues with SkyBell can message me and I can walk you through. - LuisfoOct 11, 2018AspirantFinally worked!
Thanks a lot!!! - cool2562Oct 11, 2018Star
If your Default Gateway is 192.168.1.1 use subnet 255.255.255.0 and IP address 192.168.1.201
If your Default Gateway is 10.0.0.1 use subnet 255.0.0.0 and IP address 10.0.0.201
Hope that helps people
