steve8411
Oct 03, 2018Apprentice
Firmware 2.2.1.210 released as of 10/3/18
New firmware is available via the GUI ....
Let's hope for success.
Oct 03, 2018Guru - Experienced User
Let us know if you experience any issues after updating FW.
Let us know if you apply the new FW and continue or if you factory reset the system and set up from scratch. Hopefully you can just update and continue, however if you seem to experience issue. Please try a factory reset if needed.
Davapersson
Oct 09, 2018Guide
From a rock solid V2.1.4.16 to V2.2.2.210 and I have this (huge) problem. I "hate" autoupdated firmware...
- FURRYe38Oct 09, 2018Guru - Experienced User
I would try this, download the v210 FW files, manually install them using IE11 or FF browser. Factory reset the entire system and set up from scratch. Others have mentioned this resolved problems for them:
