rhester72
Jul 11, 2017Virtuoso
Firmware V1.12.0.18 Discussion
This does indeed appear to be based on (identical to?) the last private beta V1.12.0.16 and has been released to the public. Hope it helps!
Guest mode AP isolation finally works 100% over IPv4...
- Jul 11, 2017
New Features and Enhancements:
- Supports ReadySHARE Printer for Orbi devices that are equipped with a USB port
- Updated the OrbiOS API to v3.14
Bug Fixes:
- Fixes the iOS disconnection issue.
- Fixes the Dropcam disconnection issue.
- Fixes the convergence issue when an Ethernet connected device moves from one Orbi to another.
- Fixes the issue where the Orbi app can’t find the Orbi router if the router is using IPv6 and is in AP mode.
- Fixes the issue where the Orbi app can’t display more than 20 connected devices.
- Fixes the issue where the installation assistant might not display if the device is connected to the Orbi network wirelessly.
- Fixes the issue where the 2.4 GHz backhaul setting is disabled if the fronthaul MU-MIMO and TxBF is disabled.
- Fixes the issue where IPv6 devices on the guest network can access the Orbi router’s web GUI.
- Includes security fixes for the following security vulnerabilities:
PSV-2016-0133, PSV-2017-0607, PSV-2017-0615, PSV-2017-0736, PSV-2017-2190
Download Link:
RBR50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBR50-V1.12.0.18.zip
RBS50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBS50-V1.12.0.18.zip
Stkasm
Jul 19, 2017Apprentice
KGrue wrote:I am still getting disconnects on my iPad 10.5 Pro, same as I had on previous firmwares on my old iPad Air 2.
They are only for a few seconds but enough to notice!
So, for me v1.12.0.18 hasn't improved matters at all.
Are you sure it's not roaming? We have three iOS devices of different generations - iPad air, iPad Air 2 and iPhone 6s, they do not have any problems working with wifi. Nothing changed after 1.2.0.18 update
KGrue
Jul 19, 2017Guide
Stkasm wrote:Are you sure it's not roaming? We have three iOS devices of different generations - iPad air, iPad Air 2 and iPhone 6s, they do not have any problems working with wifi. Nothing changed after 1.2.0.18 update
No, every time I have literally been sitting still using it.
