rhester72
Jul 11, 2017Virtuoso
Firmware V1.12.0.18 Discussion
This does indeed appear to be based on (identical to?) the last private beta V1.12.0.16 and has been released to the public. Hope it helps!
Guest mode AP isolation finally works 100% over IPv4...
- Jul 11, 2017
New Features and Enhancements:
- Supports ReadySHARE Printer for Orbi devices that are equipped with a USB port
- Updated the OrbiOS API to v3.14
Bug Fixes:
- Fixes the iOS disconnection issue.
- Fixes the Dropcam disconnection issue.
- Fixes the convergence issue when an Ethernet connected device moves from one Orbi to another.
- Fixes the issue where the Orbi app can’t find the Orbi router if the router is using IPv6 and is in AP mode.
- Fixes the issue where the Orbi app can’t display more than 20 connected devices.
- Fixes the issue where the installation assistant might not display if the device is connected to the Orbi network wirelessly.
- Fixes the issue where the 2.4 GHz backhaul setting is disabled if the fronthaul MU-MIMO and TxBF is disabled.
- Fixes the issue where IPv6 devices on the guest network can access the Orbi router’s web GUI.
- Includes security fixes for the following security vulnerabilities:
PSV-2016-0133, PSV-2017-0607, PSV-2017-0615, PSV-2017-0736, PSV-2017-2190
Download Link:
RBR50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBR50-V1.12.0.18.zip
RBS50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBS50-V1.12.0.18.zip
Retired_Member
Aug 01, 2017
scornwell wrote:
rexet The thing that gets me is they're aware of this thread, it's been pointed out to them multiple times and they've acknowledged it exists, but they've not acknowledged any of the issues and they've chosen, for some inexplicable reason, to stick their head in the sand instead of responding.
It's definitely a difficult situation. For some, 1.11.x broke so much functionality, and 1.12 has fixed all of that. For my 90 devices, the Orbi is back to working like it did prior to the disaster that was 1.11.x.
scornwell
Aug 01, 2017Apprentice
Retired_Member From a technical standpoint it's not simple, though arguably Netgear have been doing this a long time and should have the testing practices in place to ensure major issues like these aren't discovered by customers. But from a customer relations standpoint it's simple, fess up and face your customers. If we feel like we're being listened to we'll be far more tolerant. The approach Netgear is taking is baffling and smacks of either arrogance or incompetence. Either way, they're losing customers and their product is becoming further tarnished.
Sometimes bugs are missed, I get that, but it's how you respond that determines whether you're a company worth putting trust in. I wouldn't touch any of their products at this point.
