rhester72
Jul 11, 2017Virtuoso
Firmware V1.12.0.18 Discussion
This does indeed appear to be based on (identical to?) the last private beta V1.12.0.16 and has been released to the public. Hope it helps!
Guest mode AP isolation finally works 100% over IPv4...
- Jul 11, 2017
New Features and Enhancements:
- Supports ReadySHARE Printer for Orbi devices that are equipped with a USB port
- Updated the OrbiOS API to v3.14
Bug Fixes:
- Fixes the iOS disconnection issue.
- Fixes the Dropcam disconnection issue.
- Fixes the convergence issue when an Ethernet connected device moves from one Orbi to another.
- Fixes the issue where the Orbi app can’t find the Orbi router if the router is using IPv6 and is in AP mode.
- Fixes the issue where the Orbi app can’t display more than 20 connected devices.
- Fixes the issue where the installation assistant might not display if the device is connected to the Orbi network wirelessly.
- Fixes the issue where the 2.4 GHz backhaul setting is disabled if the fronthaul MU-MIMO and TxBF is disabled.
- Fixes the issue where IPv6 devices on the guest network can access the Orbi router’s web GUI.
- Includes security fixes for the following security vulnerabilities:
PSV-2016-0133, PSV-2017-0607, PSV-2017-0615, PSV-2017-0736, PSV-2017-2190
Download Link:
RBR50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBR50-V1.12.0.18.zip
RBS50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBS50-V1.12.0.18.zip
gbjackson
Aug 12, 2017Apprentice
I sent off a laundry list of logs, saved config files, and other info (including screenshots from a third party wi fi analyzer) to support yesterday following the most recent automatic firmware update/disabling of my satellite. We'll see what happens. The first suggestion that they had was that I change my password, because it has spaces in it. Same password that's been used for my home wi fi for the last 6 years.
Atld
Aug 14, 2017Initiate
Bought this a week ago, enjoyed the speed and coverage in the house, then it updated to the newest firmware and now lots of issues. I installed the previous version and it worked for an hour then auto update installed V1.12.0.18 and problems came back, wifi dropping, satellites loosing contact and general slowness. Has anyone heard of a coming update or how we can keep the old firmware and not auto update? Turned the old router back on for now, based on this forum seems like an issue that has been going on for too long so it will be returned this week. Can anyone recommend a comparable option?
