rhester72
Jul 11, 2017Virtuoso
Firmware V1.12.0.18 Discussion
This does indeed appear to be based on (identical to?) the last private beta V1.12.0.16 and has been released to the public. Hope it helps!
Guest mode AP isolation finally works 100% over IPv4...
- Jul 11, 2017
New Features and Enhancements:
- Supports ReadySHARE Printer for Orbi devices that are equipped with a USB port
- Updated the OrbiOS API to v3.14
Bug Fixes:
- Fixes the iOS disconnection issue.
- Fixes the Dropcam disconnection issue.
- Fixes the convergence issue when an Ethernet connected device moves from one Orbi to another.
- Fixes the issue where the Orbi app can’t find the Orbi router if the router is using IPv6 and is in AP mode.
- Fixes the issue where the Orbi app can’t display more than 20 connected devices.
- Fixes the issue where the installation assistant might not display if the device is connected to the Orbi network wirelessly.
- Fixes the issue where the 2.4 GHz backhaul setting is disabled if the fronthaul MU-MIMO and TxBF is disabled.
- Fixes the issue where IPv6 devices on the guest network can access the Orbi router’s web GUI.
- Includes security fixes for the following security vulnerabilities:
PSV-2016-0133, PSV-2017-0607, PSV-2017-0615, PSV-2017-0736, PSV-2017-2190
Download Link:
RBR50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBR50-V1.12.0.18.zip
RBS50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBS50-V1.12.0.18.zip
scornwell
Aug 18, 2017Apprentice
It seems Netgear have started censoring posts here. My last post was deleted without notice.
So they refuse to answer questions and delete posts that call them out. That's the kind of company we're dealing with.
alberts
Aug 18, 2017Star
Of course Netgear is censoring / moderating their forum their own forum.
Considering how much time i and other people wasted with support with no solution in sight, i dont understand why they dont officially concede that there are problems and they are working on a solution right now.
If i dont get results soon from support or an ETA of new firmware i will leave an appropriate review on amazon where i bought it.
Its fair game when you spend more then 1000$ on their products with flaws to warn other customers .
Customer review on amazon can help or really hurt.
Wondering what will happen now, i still give netgear a chance for an honest statement about the current situation with their Orbi system., would love to keep it.
I hope Netgear does read this and puts more effort in case #28835167). I would love to keep the system
- scornwellAug 19, 2017Apprentice
alberts It's one thing to moderate, but hiding criticism is plain dishonest.
Netgear have had a month and a half to respond, if they were going to they would have by now. I'm bettign we'll hear nothing until they have some kind of fix, but we won't be seeing any admissing they screwed up here.
Either way, I wouldn't hold my breath.
