rhester72
Jul 11, 2017Virtuoso
Firmware V1.12.0.18 Discussion
This does indeed appear to be based on (identical to?) the last private beta V1.12.0.16 and has been released to the public. Hope it helps!
Guest mode AP isolation finally works 100% over IPv4...
- Jul 11, 2017
New Features and Enhancements:
- Supports ReadySHARE Printer for Orbi devices that are equipped with a USB port
- Updated the OrbiOS API to v3.14
Bug Fixes:
- Fixes the iOS disconnection issue.
- Fixes the Dropcam disconnection issue.
- Fixes the convergence issue when an Ethernet connected device moves from one Orbi to another.
- Fixes the issue where the Orbi app can’t find the Orbi router if the router is using IPv6 and is in AP mode.
- Fixes the issue where the Orbi app can’t display more than 20 connected devices.
- Fixes the issue where the installation assistant might not display if the device is connected to the Orbi network wirelessly.
- Fixes the issue where the 2.4 GHz backhaul setting is disabled if the fronthaul MU-MIMO and TxBF is disabled.
- Fixes the issue where IPv6 devices on the guest network can access the Orbi router’s web GUI.
- Includes security fixes for the following security vulnerabilities:
PSV-2016-0133, PSV-2017-0607, PSV-2017-0615, PSV-2017-0736, PSV-2017-2190
Download Link:
RBR50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBR50-V1.12.0.18.zip
RBS50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBS50-V1.12.0.18.zip
davidwiener84
Aug 29, 2017Initiate
I am running 1.12.0.18 and have been watching my satellites connect and disconnect every couple seconds. I made a 30s giphy to show whats going on. Its extremely boring, but in the 30s loop, you can see sattellites coming and going like mad. As you can imagine, wreaking havoc on the network. Link to giphy here: http://gph.is/2x26V46
nxc
Aug 29, 2017Apprentice
davidwiener84 wrote:I am running 1.12.0.18 and have been watching my satellites connect and disconnect every couple seconds. I made a 30s giphy to show whats going on. Its extremely boring, but in the 30s loop, you can see sattellites coming and going like mad. As you can imagine, wreaking havoc on the network. Link to giphy here: http://gph.is/2x26V46
I have found on many occasions that this page can be very unreliable. It can show the satellite is disconnected when it's actually fine, and vice versa.
