rhester72
Jul 11, 2017Virtuoso
Firmware V1.12.0.18 Discussion
This does indeed appear to be based on (identical to?) the last private beta V1.12.0.16 and has been released to the public. Hope it helps!
Guest mode AP isolation finally works 100% over IPv4...
- Jul 11, 2017
New Features and Enhancements:
- Supports ReadySHARE Printer for Orbi devices that are equipped with a USB port
- Updated the OrbiOS API to v3.14
Bug Fixes:
- Fixes the iOS disconnection issue.
- Fixes the Dropcam disconnection issue.
- Fixes the convergence issue when an Ethernet connected device moves from one Orbi to another.
- Fixes the issue where the Orbi app can’t find the Orbi router if the router is using IPv6 and is in AP mode.
- Fixes the issue where the Orbi app can’t display more than 20 connected devices.
- Fixes the issue where the installation assistant might not display if the device is connected to the Orbi network wirelessly.
- Fixes the issue where the 2.4 GHz backhaul setting is disabled if the fronthaul MU-MIMO and TxBF is disabled.
- Fixes the issue where IPv6 devices on the guest network can access the Orbi router’s web GUI.
- Includes security fixes for the following security vulnerabilities:
PSV-2016-0133, PSV-2017-0607, PSV-2017-0615, PSV-2017-0736, PSV-2017-2190
Download Link:
RBR50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBR50-V1.12.0.18.zip
RBS50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBS50-V1.12.0.18.zip
scornwell
Aug 29, 2017Apprentice
@TXGunLover wrote:
gbjackson wrote:No. Installed the beta on 8/21, then did a factory reset as instructed. Haven't rebooted since (or had any reason to).
That's what happened to several of us on the 1.12.16 beta... it was fine after loading, but went flaky after a reboot.
That's exactly my experience with the latest. I can erase NVRAM, factory reset, upgrade and it works great until it reboots or drops the internet connection, then it's a mess.
alberts
Aug 29, 2017Star
Do i understand it: when you boot the new beta firmware the mess is back? I fear the time is approaching when we have to dump at least for some time or for good the orbis. How much time has everybody wasted for a product they screwed up. Is anybody here where the new firmware works as we all hope.
Netgear sucks ...
Netgear sucks ...
- spinkickAug 29, 2017Apprentice
I have about 25 devices on my orbi and my s8+ is the only issue. I've rebooted the device as well with no changes. However, I use the Orbi in access point mode, not router mode, so it does not have as much to process.
- scornwellAug 29, 2017Apprentice
Netgear sucks ...I don't think anyone has confirmed that, I should be able to later today. If I could have dumped Orbi I would have done so a month ago.
- jleecloak1Aug 29, 2017Apprentice
My Orbi has been disconnected for almost 2 months now. I asked for a refund and didn't get a response. I can't sell it on ebay for fear of someone buying it and complaining that it doesn't work because of the firmware issues.
- Retired_MemberAug 30, 2017
gbjackson wrote:
alberts wrote:
Do i understand it: when you boot the new beta firmware the mess is back?Nobody has said this. I'm running a beta firmware and can hit "reboot" tonight to see what happens.
No one has said this about the 2.0.x firmware, but at least two of us had it happen with the 1.12.x branch.
- Dustin278Aug 30, 2017Apprentice
gbjackson wrote:
I have rebooted many of times without problems with the Beta firmware and newest V2.0.0.64.. Running flawlessly for past 24 hours with latest Verizon update for my S8 and V2.0.0.64
- Mlny2Aug 30, 2017InitiateWas working from home today and my wifi was dropping every 20 mins or so. I got in touch with tech support and he had me do a hard reset. It seem to help but I doubt it. He did say new firmware will be out next month but didn't say specific day.
- jleecloak1Aug 30, 2017Apprentice
next month........
- scornwellAug 30, 2017Apprentice
My understanding is it's a couple of weeks away, so sometime in September seems likely, but don't quote me on that.
- RogerSCAug 30, 2017Virtuoso
jleecloak1 wrote:next month........
is only a couple of days away *smile*.
- scornwellAug 31, 2017Apprentice
It'll still be next month 30 days from now.
- RogerSCAug 31, 2017Virtuoso
Guess my glass is half full and yours is half empty *smile*.
My glass is full of Scotch.
- Dustin278Aug 31, 2017ApprenticeIf you look hard enough from a post this am someone posted one of the newest firmwares that is probably in beta: https://community.netgear.com/t5/Orbi/Updated-to-V1-12-0-18-now-Satellite-will-not-sync-quot-Wireless/td-p/1321830/page/2
Dustin278 wrote:
If you look hard enough from a post this am someone posted one of the newest firmwares that is probably in beta: https://community.netgear.com/t5/Orbi/Updated-to-V1-12-0-18-now-Satellite-will-not-sync-quot-Wireless/td-p/1321830/page/2Still there...
Same one I got last night from level 2 support and fixed my problems..
- DarrellRiffeAug 31, 2017Apprentice
Dustin278 wrote:Same one I got last night from level 2 support and fixed my problems..
So ... what model of Orbi system do you have? I have the RBK53 (RBR50 router and two RBS50 satellites), and I so want to try this. Right now, I'm keeping things limping along by just running the router with no satellites - not exactly what I paid for. But I'm reluctant to try the firmware without knowing what Orbi systems it has successfully fixed.
It's for RBR50 and RBS50.
I also have the RBK53 - make sure you update the satellites first and then the router! There are multiple ways to update but here is the way I did it.
1)Find ip address for each satellite and login - one of mine was 192.168.1.5 and the other was 192.168.1.3 - yours will be different I am sure but those were mine - then I loaded the RBS50 for the satellites then it took about 3 minutes each to finish
2)updated the router via 192.168.1.1 and used the file RBR50
- Mlny2Aug 31, 2017InitiateGot disconnected again so guess what? I'm hooking up Google wifi for now and then try again when net gear gets their act together.
- PhysicalEdAug 31, 2017Star
Maybe they're actually testing it this time?
- rexetAug 31, 2017Guide
Thank you for the link to the v2 beta firmware. I have updated both the router and the satelites this morning. Let's see how they behave now.
- jleecloak1Aug 31, 2017Apprentice
Did you get disconnected using the beta firmware?
jleecloak1 wrote:Did you get disconnected using the beta firmware?
I have been up and running for almost 48 hours with no problems - My S8 was disconnecting but after the latest Verizon update is running perfect
