rhester72
Jul 11, 2017Virtuoso
Firmware V1.12.0.18 Discussion
This does indeed appear to be based on (identical to?) the last private beta V1.12.0.16 and has been released to the public. Hope it helps!
Guest mode AP isolation finally works 100% over IPv4...
- Jul 11, 2017
New Features and Enhancements:
- Supports ReadySHARE Printer for Orbi devices that are equipped with a USB port
- Updated the OrbiOS API to v3.14
Bug Fixes:
- Fixes the iOS disconnection issue.
- Fixes the Dropcam disconnection issue.
- Fixes the convergence issue when an Ethernet connected device moves from one Orbi to another.
- Fixes the issue where the Orbi app can’t find the Orbi router if the router is using IPv6 and is in AP mode.
- Fixes the issue where the Orbi app can’t display more than 20 connected devices.
- Fixes the issue where the installation assistant might not display if the device is connected to the Orbi network wirelessly.
- Fixes the issue where the 2.4 GHz backhaul setting is disabled if the fronthaul MU-MIMO and TxBF is disabled.
- Fixes the issue where IPv6 devices on the guest network can access the Orbi router’s web GUI.
- Includes security fixes for the following security vulnerabilities:
PSV-2016-0133, PSV-2017-0607, PSV-2017-0615, PSV-2017-0736, PSV-2017-2190
Download Link:
RBR50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBR50-V1.12.0.18.zip
RBS50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBS50-V1.12.0.18.zip
RogerSC
Aug 31, 2017Virtuoso
scornwell wrote:RogerSC That's because you're not using VLAN tagging and don't have a gigabit internet connection to test against. It does happen for every update, under the right circumstances. It's a consistently reproducible software defect.
If the issue was memory corruption, the Orbi wouldn't have specific, reproducible issues, it likely wouldn't function at all.
I've been developing software for over 20 years, including controllers for aerial and submersible drones and other embedded systems. Memory doesn't just randomly corrupt in the way you're suggesting and there are ways of ensuring software updates are applied as intended.
This has nothing to do with enterprise vs consumer hardware, it's a software quality assurance issue and it shouldn't happen.
I agree with your point about how I use a router, that's why I mentioned that I don't do anything exotic.
By the way, I've worked for 45 years with computer software development and hardware, mostly on the enterprise end in OS design work and release engineering. HP, EMC, Intel, etc. I can't agree with you on your "memory corruption is only a software issue" point, that isn't my experience with flashing routers. So it goes.
No more from me on this one.
nxc
Aug 31, 2017Apprentice
Oof, you know the conversation has ended when people start comparing how long they’ve been in a relevant field. Let’s bring it down a notch, fellas. Clearly, some people are having problems and others are not. Clearly, some people are having mostly positive experiences. Both are possible, these are not usually exclusive. I never mentioned the word enterprise, but I won’t get into my own counter argument. Let’s get back on track, shall we?
