rhester72
Jul 11, 2017Virtuoso
Firmware V1.12.0.18 Discussion
This does indeed appear to be based on (identical to?) the last private beta V1.12.0.16 and has been released to the public. Hope it helps!
Guest mode AP isolation finally works 100% over IPv4...
- Jul 11, 2017
New Features and Enhancements:
- Supports ReadySHARE Printer for Orbi devices that are equipped with a USB port
- Updated the OrbiOS API to v3.14
Bug Fixes:
- Fixes the iOS disconnection issue.
- Fixes the Dropcam disconnection issue.
- Fixes the convergence issue when an Ethernet connected device moves from one Orbi to another.
- Fixes the issue where the Orbi app can’t find the Orbi router if the router is using IPv6 and is in AP mode.
- Fixes the issue where the Orbi app can’t display more than 20 connected devices.
- Fixes the issue where the installation assistant might not display if the device is connected to the Orbi network wirelessly.
- Fixes the issue where the 2.4 GHz backhaul setting is disabled if the fronthaul MU-MIMO and TxBF is disabled.
- Fixes the issue where IPv6 devices on the guest network can access the Orbi router’s web GUI.
- Includes security fixes for the following security vulnerabilities:
PSV-2016-0133, PSV-2017-0607, PSV-2017-0615, PSV-2017-0736, PSV-2017-2190
Download Link:
RBR50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBR50-V1.12.0.18.zip
RBS50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBS50-V1.12.0.18.zip
Dustin278
Sep 01, 2017Apprentice
A couple things that I would try would be turned down 2.4 transmission to like 50%or try a different Channel on your 2.4 and you something like 1 or 6 or 13
DarrellRiffe
Sep 02, 2017Apprentice
I've temporarily resolved my dropout problem by simply turning off both satellites. Stable, but I don't get the coverage that I need in my house. When I first installed the RBK53, it was fantastic. Two firmware updates later (including the beta), and I basically have three expensive paperweights. So tomorrow, I'm getting a new router. I haven't yet decided which one, but I'm researching tonight. I do know that it will not have the Netgear brand on it.
Adios!
- ikjadoonSep 02, 2017Star
So I take it that returning my Orbi to Best Buy four weeks ago was a good move? My old router is showing its range and I was tempted by Orbi once more, after seeing the update land decently well.
I can't take the stress and frustration of dropped connections; there's too much work to be done to bother with this day-in and day-out. Adios, once again, Orbi.
- scornwellSep 02, 2017Apprentice
Unfortunately I can now confirm the latest beta firmware (V2.0.0.64), only resolves my issues until the next reboot. I can reproduce the issue with 100% reliability.
I couldn't be more pissed off that I've wasted so much time with support, gathering logs and taking endless screenshots, for them to deliver a supposed fix that clearly wasn't tested at all.
- nxcSep 02, 2017Apprentice
scornwell wrote:Unfortunately I can now confirm the latest beta firmware (V2.0.0.64), only resolves my issues until the next reboot. I can reproduce the issue with 100% reliability.
I can confirm this as well. Everything was great until I rebooted the router. Then downstream speeds dropped to 1/10 what they were. I'm now in the process of rolling back to v1.12 and doing the NVRAM dance. SMH.
